Where should I locate my old .CTB files and .PC3 Files for my old plotter files from WIndows?
Or, if you could explain it to me clearly, what is the best way to create a new plotter configuration for a plotter not connected to my system so that I can set up to print a 24x36 sheet, most likely as a PDF file so that I can take them to a printer service for printing.
I also want to do this for an 11x17 or a 12x18.
Thanks.
AutoCAD for Mac doesn't use .PC3 files at all by design.
CTB files go here:
"~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Plotters/Plot Styles" (Library folder at your Home folder)
About plotting (saving to PDF) - you can create Custom Paper Sizes for plotting (actually saving to PDF) on paper that your current System printer doesn't support.
You can create Custom Paper Sizes in Print or Page Setup dialogs, just select Manage Custom Sizes from Paper Size drop-down list.
Then use Custom Paper Size for your Page Setup (Custom Paper Sizes will appear at the bottom of Paper Size list)
Maxim
I'd differ a little on the path for CTBs. Thats the OOTB path; given the option I'd place them somewhere easier to get to and adjust the search path accordingly.
