I have Autocad LT 2014 and use a macbook pro mid 12 with Yosemite Beta 5.
Firstly I have not had any issues with the OS X as far a I am aware. I am self taught over the last 6 months and need to create very basic 2D drawings for my business and have managed to muddle through so far.
Plotting - On some drawings when I plot them to PDF and save to desktop, random lines on the drawing are missing. whether having drawn them in model space or paper space. I have inserted a crane block and the outline of the crane will be missing in PDF, yet the internal lines will be there.. If I send to the CAD office at work it will open fine for them. So I am not sure its a layer problem. They are not sure why.
Rotation - Some drawings sent to me are at 45 deg and the cursor is Red and Green. I really only need to see the drawing at 90 deg on the page and plot the same. How can I alter the DWG and rotate it. I can of course highlight and rotate, but is there a way to set the drawing properly so when I plot it is correct ?.
Apologies if this is kindergarton stuff.
Cheers Steve
Maxim
Thanks for the plan command, the drawing I was using scaled down to a minute size but when I zoomed in, the cursor was correct and I was able to rotate it and it was better. Same applied in a view port in template. So thanks for that.
Regarding plotting. I draw onto an existing drawing sent to me and all is fine in model and paperspace. When I plot using my default programme I assume. In PDF random lines are missing from the drawing. I could draw a circle with an intersecting line and the line would be missing. Parts of a CAD block I have inserted would be missing.
I sent the DWG and the PDF to my office and they plotted to PDF fine !
Could it be the plotter that is being used, I have an epson printer installed. This issue does not seem to manifest itself with all DWG. If I draw my own from scratch I have no problems. I would have thought a layer issue, but as the office managed it without adjustment I am not sure.
Maxim
It seems to be a compatability problem with Yosemite 10.10. All the warnings are not to upgrade yet, until the service packs are available from Autocad...............too late :o(
I will now wait for them and see if that resolves the issue.
Thanks for your time
Regards
