Hello! I'm having some trouble with plotting on my autocad for mac, along with the many deficiencies on this topic, i just can't find a way to make the "last used settings" to work, i have to plot around 50 drawings, and each time i have to edit plot settings again, it's annoying and a big waste of time. Anybody can help? Thanks!
check this link, it might be one of the many useful features that you do not get with AutoCAD for CAC
http://forums.autodesk.com/t5/AutoCAD-for-Mac/What-you-don-t-get-in-ACAD-for-Mac/td-p/2801342
Hi leslie.chavezs,
@leslie.chavezs wrote:... i just can't find a way to make the "last used settings" to work, i have to plot around 50 drawings, and each time i have to edit plot settings again, it's annoying and a big waste of time. Anybody can help? Thanks!
Actually it is not very difficult.
Once you have setup first print job, and you satisfied with results, do the following:
- open your second (3rd, 4th...) drawing
- choose File -> Print,
- in Print dialog click on "Edit Page Setup"
- in Page Setup dialog check-mark "Use available page setup"
- from drop-down list select "<Previous plot>" (it changes back to <None>, but don't worry, settings is already imported)
- click "OK" in Page Setup dialog
- click "Preview" or "Print" in Print dialog
- that is all
HTH
Maxim
PS And here is not you, by chance? -> http://www.kulay-diwa.com/leslie_de_chavez
