AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
PDF Underlay Line weight and software to convert PDF to DWG
2 REPLIES 2
4651 Views, 2 Replies
I have 2 questions.
1)  Is there a way that I can control the line thickness of the PDF underlay?  I notice that when I pan around the very thin lines appear for the pdf, as soon as I stop, the line thickness comes back.  Could I disable line thickness for a PDF underlay?
2)  Can anyone recommend from their experience a good PDF to autocad file converting software for the MAC?
Thanks in advance!
Kevin
2 REPLIES 2
pendean
1. No, AutoCAD does not edit or alter the content of PDF files.
2. I will leave for others to recommend, please wait.
maxim_k
Hi Kevin,
1) You can not control thickness in PDF underlay, you can only turn ON or OFF Layers (if any) in PDF, switch color/monochrome mode and snap to elements in PDF.
2) Personally I use two applications:
- Inkscape - free, but it can only export PDF to DXF and it export only lines, circles and polylines, text objects and fills doesn't converted to DXF
- Adobe Illustrator - not free, but it can open PDF files natively and save DXF and DWG format directly and can export text to DWG
EDIT: forget to mension about pdf2cad application which you can find in MAS, but it is also not free and I have not tried it, but the review in MAS does not inspire:
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
