I'm using AutoCAD for Mac 2013. The PDfs that I get when using 'save as PDF' are large, very slow to display on the screen and hard to read. They print fine. I have attached an example. Anyone know how to fix this? The desired outcome is a smaller file size, screen legibility and faster display without looking like each layer is be redrawn.
Thanks!
I think, I can explain the reason for large size and complexity of the PDF file you get when you "save as PDF" from AutoCAD for Mac.
In fact, saving to PDF from AutoCAD in Mac OS differs from saving to PDF from AutoCAD in Windows - they use different PDF output software.
I'm absolutely sure, that:
- you are using CTB file with line end and line join style different from default "Use object line join / line end style":
- probably you are using in your drawing polylines with Width greater than 0.00. In this case the width of polyline created in resulting PDF as collection of filled triangles and not as single polyline with fixed width.
As the result of such settings each of "wide" object renders to PDF file from AutoCAD for Mac not as one object with fixed width, but as a group of objects (filled triangles). For example: each hatch dot (I see you are using DOTS hatch pattern) renders as a group of filled triangles if you are using CTB file with line end and line join style different from default "Use object lineweight/line end style:
So file size grows and complexity of PDF increases so that PDF reader can not display file faster.
Maxim
Maxim,
I am having the same issue as OP and was wondering if fixing the plot style, or rather, altering it would effect how pdfs are created using the windows version of AutoCAD. At the firm I'm with right now, two of us are using AutoCAD LT 13 for Mac and everybody else is using a mixture of versions on Windows. We all direct our plotsyles, templates, etc. to a folder on our server so I'm afraid to alter any sort of template or file that others may be using just so my plots become smaller.
Thanks, that drastically reduced my pdf file size. A four sheet publish set went from ~17mb to around 2mb - still larger than what the Windows counterparts are producing, but adjusting the CTB worked wonders. I imagine text may play a roll in the extra file size, I've read a few posts on here discussing how to reduce PDF file size and that was one of the things to look into. Sorry for hijacking your post OP - did this solution help you as well?
Reducing PDF file size by tweaking PDF compression on Mac affects only raster images inside PDF and doesn't affect problem with vector data ("exploded" fonts for example)
Maxim
I am at my wits end with trying to reduce my pdf file size. My dwg is around 400K but the pdf generated is 1.5MB. I have tried everything I know but still no resolution. I tried selecting the monochrome CBT and editing it per the graphic here but it doesn't help. Any other suggestions?
Welcome to the Autodesk Forums!
Does your DWG file contains a lot of TEXT objects?
If so, most likely you can not reduce the size of PDF output in AC for Mac, because of the OS limitations it doesn't allow to embed True Type fonts into PDF file (which could reduce TEXT overloaded PDF file).
Maxim
Thanks for your response. I don't believe there is an abnormal amount of text but then I am not really sure what alot constitutes? Is there something I can do to the text to reduce the file size? I know of several engineers using Autocad for Mac. I even have some of their drawings. They have more text in their drawings but their pdf file sizes are about the same as their dwg?
Maxim,
Thank you for all of your help. I would be gald to. Also, I do not have a custom cbt that I am using. I have tried using the default of none and monochrome using the built-in cbt's. I selected none and then tried monochrome.cbt with no modifications. Thanks so much for your help!
Maxim,
Thanks a ton for your help! I currently have AutoCAD LT 2013 for the MAC. Do you think this is something that is fixed or is it just a MAC OS thing? I will try the AutoCAD360 and let you know. Thanks again for your insight and help!
Maxim,
If I plot my drawing online the file size goes from >500k to less than 40k? I just dont get it. It sure seems like there would be a fix for this outside of having to generate plots online? Thought you may want to know. Thanks again!
