I am currently using autocad 2014 student version on my macbook Pro.
When I start the clean screen on AutoCAD (⌘+0) the palettes disappear...
Every time I start the clean screen I must restart all palettes (⌘+1 , ⌘+3 , ⌘+4)
Is there a possibility to save my palettes in the clean screen on AutoCAD 2014?
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Yes, I also see such behavior.
I know a trick to show them, but at first I want to ask you:
Which palettes you want to display in Cean Screen mode?
Maxim
Thanks for your quick reply!
In my previous post I have attached a screenshot where you can see which palettes I use in the Clean Screen.
Here they are:
- Tool Sets
- Command Line
- Layers
- Properties Inspector
- Status Bar
I hope you can help me because it's really annoying to constantly re-activate the palettes when I start the Clean Screen in AutoCAD
@THMSNL wrote:
Here they are:
- Tool Sets
- Command Line
- Layers
- Status Bar
Wow! The same as mine
So, download attached archive - it includes acaddoc.lsp file that redefines CLEANSCREENON command in current AutoCAD session.
Quit AutoCAD.
Unzip acaddoc.lsp to ~/Library/Application Support/Autodesk/roaming/AutoCAD 2014/R19.1/enu/Support/ folder (if you already have one in this folder you need to append existing acaddoc.lsp with my code, but hope you haven't it).
Launch AutoCAD and try Cmd+0.
Maxim
Thanks it works!
Here I was looking for!
But now I have a another question.
When I open Clean Screen (⌘+0) the palettes are not in the correct position where I would like to have them. (see attached screenshot)
Is it possible when I start Clean Screen that the palettes immediately get into the right position, or do I have to drag them to the right place on the screen every time I start Clean Screen.
Thanks for your help
It's not that big a problem that the position of the palettes are incorrect.
The important thing is that the palettes are there in the Clean Screen!
If there is a solution in the future for the location of the palettes, let me know!
Thank you so much for all your help 🙂
