Is there a way in which sheets(layouts) can be ordered within quickview? Once created I cant seem to drag them or move them around to the order I want.
Solved by jtorrebueno. Go to Solution.
Hi John,
As usual, I can drag thumbnails in QuickView window to reorder them:
And you?
Maxim
Hi Maxim,
I have it working now after a reboot, restart, etc.
It does seem to be intermittant and will sometimes not work, so I'm guessing there is a bug in there somewhere as I've noticed this on a few drawings now.
John
Hi Maxim,
I'm using 2014 and the OS is 10.8.3
The audit command does not detect any errors, but if I close AutoCAD then re-open the problem seems to go away.
John
Hi Maxim,
Not a great deal of layouts - 8 or 9
It seems to work for a while, but after switching layouts, creating vports, etc it seems to stop working until I restart AutoCAD
There is another thread where it is revealed that reorder does not work if caps lock is on. I had the same problem and found by chance that taking caps lock off fixes this.
