AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Only part of object moves.
6 REPLIES 6
451 Views, 6 Replies
I'm unable to move entire object, btw. I can move only part of it. I use AutoCAD 2013 Mac.
6 REPLIES 6
maxim_k
Could you clarify? Which object you can not move? Do you use MOVE command or you are trying to move with grips?
At least one screenshot, please... and better - attach problem drawing here.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Ugh. But I had already attached an image. Sorry, I can't attach, why? OK, it was Safari's problem.
maxim_k
Although attaching DWG file will be better.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes, I know this. Problem was with Safari. I used Chrome and it woks properly.
Sorry, I can't share dwg file anymore. I draw it using PLINE tool. You can see attached screenshot in my previous post.
maxim_k
Objects in your drawing are constrained with Geometric constraints - you can see icons of them.
So you need to delete these constraints.
From menu Parametric select Delete Constraints, it will ask to select objects, type ALL at the command prompt and hit Return.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes. You are awesome!
Thank you!
”Boost
