AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
object snap buttons
5 REPLIES 5
emma_louise26
2271 Views, 5 Replies
object snap buttons
Hi There
I have recently started using autocad on mac - very different to windows i know - no ribbon etc.
However when I am following my college work it tells me to select the "snap from" icon in my object snaps toolbar. I dont have this toolbar either on my mac version and is wondering does anyone know how i select this?
Many Thanks
E
5 REPLIES 5
maxim_k
in reply to: emma_louise26
Welcome to the Autodesk Forums!
If you are using mouse, you can press Shift key on keyboard and right-click with mouse, than onscreen menu appears:
Select From in it.
You can call this OSNAP overrides menu with Shift+Right-click while you are inside command.
If you are using Trackpad on MacBook, than the only option is to type word "from" at the command prompt when AutoCAD asks for point input and hit Return to continue:
Command: LINE
Specify first point: from
Base point: <Offset>:
Specify next point or [Undo]:
And of course in both cases you can add button to ToolSets palette via CUI command:
than use this button when you need it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
emma_louise26
in reply to: maxim_k
unfortunately when i press alt and right click nothing happens any suggestions??
maxim_k
I wrote about SHIFT key:
http://en.m.wikipedia.org/wiki/Shift_key
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
emma_louise26
Sorry my error i meant shift key and right click..... nothing happens though :(, why is this?? I have the new version wireless touch mouse, still has the click feature though could this be the issue??
I have just read one of your earlier posts and enable second click in my mouse settings......thankyou all sorted 🙂
”Boost
