I am working in 3D and all of a sudden ,when I use the 3D orbit,it is continuous and will not stop orbiting until I stop the command.The Windows version had "continuous" as an option,but I can't find a way to turn this off on my Mac.
Any ideas?
Hmm,
Very interesting, because AFAIK there is no "continuous" option in 3DORBIT command in AutoCAD for Mac.
Could you post here your drawing that cased continuous orbit inside 3DORBIT? (you can delete all information in it)
Maxim
It seems it was one of those inexplicable temporary bugs.I tried saving,then closing the file,then closing AutoCAD,and the orbit would not stop rotating.
Now a couple hours later after moving away from AutoCAD,but not closing it,I have opened the file to send to you,and No More Continuous orbit.
I attempted Redraw a number of times,I had all other programs closed,and can't figure it out.
Thanks for replying,I'll contact again if it re-occurs.
Hello again,
I am encountering the same problem where I initiate 3d orbit and it spins to a certain view then stops.
attached is the file.
Sincerely,
Rick
Hi Rick,
I can not reproduce issue you described with your file on my Mac.
3DOrbiting stops as soon as I release mouse button.
Maxim
