autocad lt 2014 trial version, running OS 10.9.2 (mavericks) on a MBP
similar to a post from last year, i have no menubar or pull down menus in autocad
have run the service pack, have reset application options in preferences, no joy yet.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Seems that this solution:
helped to resolve similar issue for AC LT 2013 from MAS.
You can try to do the same? but for AC 2014 LT you need to search .CUI files here:
/Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Resources
and then put them there:
~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2014 Standalone/R19.1/enu/Support
(the Library folder in the last path is inside your Home folder, not in the root of your Mac HD)
Maxim
I just tried following your steps because I'm having the same problem but nothing worked.
Do you have any other suggestions? I can't see my menu bar, or toolbar (I get a small square in the upper left corner which I can't enlarge), neider can I use anny "command" shortcut on my keybord (commnad copy, command paste, commnad save, command undo, etc).
I really appreciate your help. I have AutoCad LT 2014 for Mac.
What files do you have inside
folder?
You can post screen shot of this folder in list view.
Maxim
Same problem here.
Can find the cui. files, but can't find the roaming file in the library.
How do I solve this problem?
Esther
