AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
no menubar in autocad lt 2014
6 REPLIES 6
4056 Views, 6 Replies
autocad lt 2014 trial version, running OS 10.9.2 (mavericks) on a MBP
similar to a post from last year, i have no menubar or pull down menus in autocad
have run the service pack, have reset application options in preferences, no joy yet.
6 REPLIES 6
maxim_k
Welcome to the Autodesk Forums!
Seems that this solution:
http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/Autocad-Lt-2013-app-store-download-no-menu-bar...
helped to resolve similar issue for AC LT 2013 from MAS.
You can try to do the same? but for AC 2014 LT you need to search .CUI files here:
/Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Resources
and then put them there:
~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2014 Standalone/R19.1/enu/Support
(the Library folder in the last path is inside your Home folder, not in the root of your Mac HD)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
That did the trick, thanks
I just tried following your steps because I'm having the same problem but nothing worked.
Do you have any other suggestions? I can't see my menu bar, or toolbar (I get a small square in the upper left corner which I can't enlarge), neider can I use anny "command" shortcut on my keybord (commnad copy, command paste, commnad save, command undo, etc).
I really appreciate your help. I have AutoCad LT 2014 for Mac.
maxim_k
What files do you have inside
folder?
You can post screen shot of this folder in list view.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Same problem here.
Can find the cui. files, but can't find the roaming file in the library.
How do I solve this problem?
Esther
maxim_k
Welcome to Autodesk Forums!
Hi Esther,
Where you can find CUI files? Do you mean you can find them in AutoCAD application folder?
And you should look for "roaming" folder inside Library folder that is in your home folder:
Users/YOUR_USER_NAME/Library/Application Support/Autodesk/roaming
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
