AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
New 3Drotate gizmo won't show up, only rotates about z.
4 REPLIES 4
ekias
5773 Views, 4 Replies
  I'm drawing 2D figures using lines in 3D space because I would like to use the realistic coordinates (rather than projections) to maintain accuracy.  Only, I've realized that I cannot put text anywhere but on the x-y plane.  My idea is to rotate the figure 90 degrees once it is constructed so that it is parallel with the x-y plane and then the text will be in view.  When I try to use the 3DROTATE command to rotate the figure, the gizmo does't show up and the program only allows rotation about z.  I need rotation about x.  Does anyone know why the gizmo isn't showing up?  Should I just use the old ROTATE3D command?
Thanks!
Evan
Tags (2)
4 REPLIES 4
maxim_k
in reply to: ekias
Hi Evan,
in order to see Gizmo, you have to change view direction from orthogonal to something different, then AutoCAD will switch temporary to 3D visual style and you will see Rotate Gizmo:
HTH,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ekias
in reply to: maxim_k
Great Maxim!  Thank you!
nisalamadu
May i know how can i change it?
maxim_k
in reply to: nisalamadu
Welcome to the Autodesk Forums!
Hi
If you asking about how to change view direction - you can use for example 3DORBIT command, or use ViewCube to rotate view,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
