I'm drawing 2D figures using lines in 3D space because I would like to use the realistic coordinates (rather than projections) to maintain accuracy. Only, I've realized that I cannot put text anywhere but on the x-y plane. My idea is to rotate the figure 90 degrees once it is constructed so that it is parallel with the x-y plane and then the text will be in view. When I try to use the 3DROTATE command to rotate the figure, the gizmo does't show up and the program only allows rotation about z. I need rotation about x. Does anyone know why the gizmo isn't showing up? Should I just use the old ROTATE3D command?
Thanks!
Evan
Solved by maxim_k. Go to Solution.
Hi Evan,
in order to see Gizmo, you have to change view direction from orthogonal to something different, then AutoCAD will switch temporary to 3D visual style and you will see Rotate Gizmo:
HTH,
Maxim
Welcome to the Autodesk Forums!
Hi
@Anonymous wrote:
May i know how can i change it?
If you asking about how to change view direction - you can use for example 3DORBIT command, or use ViewCube to rotate view,
Maxim
