AutoCAD for Mac General Discussion
Active Member
paarch
Message 1 of 8 (477 Views)
My files disappear.
477 Views, 7 Replies
12-15-2011 02:20 PM
First off, this is my current machine:
27-inch iMac
3.4GHz Intel Core i7
8GB 1333 MHz DDR3
Mac OS X Lion 10.7
Here is my issue. I WAS running Architectural Desktop 3.3 (I know EXTREMELY OLD) on a PC. Recently purchased new iMac running AutoCad 2012 for Mac and have been transferring files from the old machine to the new one.
After transferring the files, I open AutoCad for Mac, edit a file, save the file, and close AutoCad. When I go to the location of my recently transferred files, ALL of the files (except the file I editted and saved) have disappeared. This includes, DWGs, PDFs, JPGs, Word Documents, etc.
The Harddrive available space is the same as it was before I transferred the files. The trash is empty. Other than the One file I editted, it appears that I never transferred the files in the first place.
I've tried it multiple times... with multiple flashdrives... to multiple folders...  and it keeps doing the same thing.
HELP!!!!
Picture 1: Shows available disk space as 987.34 GB before transferring the files.
Picture 2: Shows available disk space as 986.41 GB after transferring the files.
Picture 3: After Editting and saving a file... the files that were transferred have disappeared. Available space has reverted to 987.34 GB available. Trash is empty.
maxim_k
Message 2 of 8 (466 Views)
Re: My files disappear.
12-15-2011 07:55 PM in reply to: paarch
There is a bug in AC 2012 for Mac- if you open andcsave DWG file inside folder, which name contains # sign, AutoCAD erase ALL files inside this folder. So - don't use # sign in folder names. This issue should be resolved in upcoming update for AC for Mac
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
paarch
Message 3 of 8 (452 Views)
12-16-2011 01:00 PM in reply to: maxim_k
THANK YOU! It seems to work. I was tearing my hair out trying to figure this out.
Employee
Leaf.chai
Message 4 of 8 (410 Views)
01-11-2012 02:30 AM in reply to: paarch
Can you have a retest after you get the AutoCAD for Mac 2012 update 1?
Leaf
Autodesk Test Engineer
Active Member
paarch
Message 5 of 8 (402 Views)
01-11-2012 09:10 AM in reply to: Leaf.chai
Downloaded the patch.
Replicated the process I had issues with before, and the files are no longer being deleted.
However, once I save a drawing and close it, autocad freezes, crashes, and I get the Send Error report pop up.
So... improved, but still screwy.
maxim_k
Message 6 of 8 (400 Views)
01-11-2012 09:24 AM in reply to: paarch
Does this happens always? with every file?
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
paarch
Message 7 of 8 (397 Views)
01-11-2012 09:58 AM in reply to: maxim_k
Just files that are located within a folder with "#" in the name.
Doesn't crash in files located in folders without.
Employee
Leaf.chai
Message 8 of 8 (386 Views)
01-11-2012 05:57 PM in reply to: paarch
Have you sent the crash report after quit crash?
If you send, can you give me your e-mail address which used to send crash report?
I will try to repro this and keep on tracking with it.
Leaf
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
