AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Menubar and tools are gone
6 REPLIES 6
cstifter
1882 Views, 6 Replies
Hey,
I just updated my Autocad 2014 student version to the 2015 student version, because i had some crashes with the 2014 version on yosemite.
the download was easy and i installed it. but no the menubar and the tools are gone. i searched for a solution, and i tried everything, but nothing helped. i reinstalled it, i was resetting the options, i really did everything, but i can´t get the toolbar and the menubar back. it is really important for me, to fix that problem as soon as possible, because i´m on a school for architects and i have to finish my project.
i´m sorry for my english 🙂
maybe you should now that i´ve got a mac with yosemite (OSX 10.10) running on it.
here a screenshot:
6 REPLIES 6
maxim_k
in reply to: cstifter
Welcome to Autodesk Forums!
Please look at this topic:
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-lt-2013-app-store-download-no-menu-bar...
It is about 2013 LT and 2014 versions, but you can try the same solution for 2015 version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
cstifter
in reply to: maxim_k
Thank you, for the solution and the fast support 🙂
this way worked and everything is fine 🙂
thanks! 🙂
How did u find the roaming folder in the Library? I can't find it. I have the Autodesk folder inside the Application Support in the Library, but inside it I can only see two folders: ADLM and ADUT,
maxim_k
Are you sure you are looking in right place? The Library folder I mentioned in my post is inside your Home folder and not in the root folder of your Mac hard drive.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
gionata.carcioffi
I love you, you saved my life! You are the best man!!!!!!!
It all works perfectly!
mgraciacl
I have the same problem, my menubar and command + Z, doesn't work in my Autocad 2015. I've  tried replacing the cui  documents mentioned in the Library folder (the one that is in the Home folder), but I still cannot solve the problem. Please help me ASAP, I've tried so many times and it is still the same.
Thanks!!!
”Boost
