AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Menu Bar display TIME DATE AND BATTERY LIFE
4 REPLIES 4
292 Views, 4 Replies
HEY GUYS IM RUNNING THIS ON MY MACBOOK PRO WITH MAVERICKS 10.9.4 AND MY MENU BAR WITH FILE EDIT VIEW ETC. SHOULD HAVE MY DATE, TIME AND BATTERY LIFE. LIKE IT DOES NORMALLY. IT IS THERE WHEN THE PROGRAM IS FIRST STARTING UP BUT DISSAPEARS AS SOON AS IT IS DONE FULLY LOADING. ANY IDEAS?
4 REPLIES 4
maxim_k
Welcome to Autodesk Forums!
Could you post screenshot of how it looks like after loading AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
this is when im active in autocad as you can see it displays my name but not the time date or battery life. as you can see it is supossed to have like the second screen shot
maxim_k
You need either to remove your login name from menu bar:
simply Command-click and drag one of the menubar icons off the menubar, towards the middle of the screen.
Or try to rearrange the items on the menu bar - move your login name to the left in order to let date and time be visible when AutoCAD is active:
to move the icons (and login name) around, simply hold the Command button down on your keyboard, and then drag and drop the icons into the order that most pleases you. You won’t be able to move the Notification Center or Spotlight icons, or third-party icons, but the rest of them–like the Bluetooth or the Wi-Fi icons–can be rearranged with ease.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
And, you can also switch to small icon instead of your user name:
Go to System preferences, open Users & Groups pane, click on Login options on the bottom left, financial on pad lock to enter your password to make changes, then on the right select "Icon" from drop down list "Sow fast user switching menu as"
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
