I have not been able to attach materials to my parts. The materials browser is empty and I can't get it to add materials.
I have typed the search path to the materials file into it but to no avail.
I know it's easy and I'll feel foolish when I get the answer but until then I'm just frustrated.
Solved by getae113. Go to Solution.
Solved by maxim_k. Go to Solution.
Hey maxim_k,
Thanks for the good tip. I am obviously new, and was wondering if you coulf help me unlock the materials in my library. I am trying to apply them to a roof pannel (mat aluminum), though when I open the material browser (RMAT) all of my materials are locked. I have a huntch that I might have missed something in the instalation process, but still have no idea where to start correcting this problem.
Thak you for any help that you can provide!
Thank you!
And good to know. It did start lettgin me apply them after I figured out that they would appear in the usable materials box above, but it took me a minute! I appriciate your help, and I'm sure will ahve more questions in the future.
TH2015
Hello there,
I have a quick question regarding materials. Indeed I can’t create my own materials in Autocad 2019 for Mac. I can’t edit them either because they are locked and the library is really poor in samples. This is a huge disadvantage . It ruins the whole project. The program is useless without the finishing materials. Why is that because I’m highly disappointed?
Hi Maxim,
Please tell me how do I import materials into Autocad Library. There has to be a solution. I don’t believe they left it just like that with those poor choices by default. I’m asking you because you are among the few who knows very well this program. Are there other libraries from other CAD programs compatible with this one? Thank you.
Hi Maxim,
And thank you for confirming there is no way to import new materials in AC for Mac. I did tried all kind of combinations but nothing worked. I will take your advice from now on. Is there a way in AC to slice a solid along a curved line, arc etc? In the end to have the shape just like the curved I used to slice it. Please let me know if you find anything. The object option in slice command doesn’t do that. It slices the whole plan and no curves. Right now I’m doing it creating another solid and using the subtracting tool, quite inefficient because it takes time. Thank you.
Hi Tesha,
You cannot slice with arc, but you can slice with surface - look at the attached drawing.
I created surface from ARC with EXTRUDE command and use "Surface" option in SLICE command.
Hi Maxim,
I need a little help from you. I have 2 cylinders who touch each other in one point at an angle and I want to close the gap smoothly between them . I tried the loft command but doesn’t do a good job. Is there a command in AC that highlights the gap and fill it?File attached.
My Regards,
Tesha
Hi Tesha,
Is yellow 3D Solid what you want to get?
I just want to close the gap between these 2 cylinders smoothly without any lines showed in Realistic View. Loft command does close the gap but a little... rough. I would like the transition to be smooth and unnoticeable when zooming the object just like a filletedge. I can’t change the angle either to make it bigger and look better when closed. It can definitely be done with two axis lines an arc and sweep a circle for the whole length. However, I’m interested if there is any command in AC to patch these two smoothly, besides Loft. I’m not interested with the solid created by the loft if this is what you mean by yellow solid.
Regards
I'm afraid - it is impossible and primary because those two cylinders has such kind of intersection:
BTW, I created my yellow solid with SWEEP command.
I also tried SURBLEND command:
but I had to reposition cylinders at first (see attached dwg)
Hi Maxim,
Yes it looks better yours. I will change mines from solid to surface then, use Surfblend to gap it and change back to solid after that (hopefully it works). Thank you again for your help.
Hi Maxim.
I have a quick question for you. Almost all my metals in the Materials Section are shown in black when applied to a solid. I couldn’t find the solution to make it show the real color and texture. Any idea why is this happening? Thank you.
Tesha
