AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
LT2012 for Mac - Dialog Box disappearing
11 REPLIES 11
Message 1 of 12
2957 Views, 11 Replies
Running into a serious issue where certain dialog boxes are not appearing. The app runs as if the dialog is present (can't edit and menu bar is greyed out, but the box is nowhere to be found.
The two instnaces so far:
- Edit Page Set-up...: The print dialog shows up, but when I select the "Edit Page Setup..." button the app runs in a mode as if the box is there but it can't be seen. Hitting escape brings me back to the original print dialog box.
- Edit Attributes for a block: Same as a above, except the box shows up for a split second and then it's gone.
Things I've explored with no succes:
- checked all spaces
- hidden or closed all other windows
- permission repair
- tried on multiple dwg files
- Clean Screen mode
- hide all pallettes
- rebooting
Any thoughts?
Thanks in advance.
Byron
11 REPLIES 11
Message 2 of 12
maxim_k
Reinstall AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 12
in reply to: maxim_k
Thanks...I guess I could give that a shot. Was hoping that it'd be a last resort.
B
Message 4 of 12
Reinstalling didn't work...deleting pref files seems to have done the trick.
Message 5 of 12
cwilk
Could you tell me where the preference file is located please?
Thanks.
Message 6 of 12
maxim_k
in reply to: cwilk
It is in "~/Library/Preferences" folder, the name of the file is: com.autodesk.autocadlt.plist
If you are on Lion, then:
"Holding down the Option key will show the “Library” directory as an option in the Finders Go menu. The other nice thing about the Go menu is that after you have accessed ~/Library on multiple occasions, it will start to appear in the “Recent Folders” submenu for easy repeat access."
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 12
Hi there,
I am experiencing the exact same problems that you have already described. The dialogue box fails to appear when I go to "page setup" from plot mode. Everything freezes up and won't go back to normal till I've hit "escape".
I have tried locating "com.autodesk.autocadlt.plist" but it isn't in my library directory under preferences.
Any suggestions???
Thank you!
Sidra
Message 8 of 12
Are you looking in the system Library vs user Library? The preference file should be in the Pref folder in the user library (user library hidden by default - you would need to select the Go menu in teh Finder while holding down the Option key to reveal the user Library, as Maxim describes above.)
Thx,
Byron
Message 9 of 12
jess05
Hii
I've tried deleting the preference file but didn't work. Any othe solution??
Thanx
Message 10 of 12
kathy
in reply to: jess05
This is happening to me when I try to ATTEDIT - I see the box pop up momentarily and then it goes away and I cant edit my blocks that are tied to attributes.
I might have turned something off with att(...) command line (0,1,2). Does anyone know how to fix this?
Message 11 of 12
kathy
in reply to: kathy
Looks like my command is EATTEDIT
Message 12 of 12
I fixed the problem, but I also found difficulty when only removing the com.autodesk....plist file from the preference folder.  I had to remove all of the files associated with autodesk from the pref folder before the problem was compleatly eliminated.
”Boost
