AutoCAD for Mac General Discussion
New Member
0 Kudos
Post 1 of 4
Lines and Hatch selectively DO NOT print!
371 Views, 3 Replies
01-08-2013 12:38 PM
I can export my drawing pages to PDF, and on screen everything is there and looks fine.
However, when I print my drawing pages either from the page layout, OR print from the exported PDF, random lines do not print at all, and certain parts of hatching do not print either!
Has anyone had this happen? I've tried re-saving my PDF's to JPEG, or even doing a screen-shot of them... and that actually makes the problem worse and many lines disappear.
Please help!
532 Kudos
Post 2 of 4
Re: Lines and Hatch selectively DO NOT print!
01-08-2013 05:27 PM in reply to: s_b_55
If you can see all lines in PDF file on screen, but some of lines disappears on paper, then the case could be in printer (plotter) you use.
Could you, please, post your PDF here?
Maxim
Architect
MARSS
MacACAD | MARSS
New Member
0 Kudos
Post 3 of 4
01-08-2013 05:48 PM in reply to: s_b_55
I had thought that too, but I'm on my second printer and have had the issue with both.
Also, if I save an exported PDF as a JPEG, a lot more lines disappear. So it's something digital that's happening... not to do with the printer. Very strange.
I'll attach an exported PDF (all lines show but not all print), and a JPEG (drawing is gone other than annotations)
532 Kudos
Post 4 of 4
01-08-2013 07:48 PM in reply to: s_b_55
Hi Stephanie,
I've printed your PDF on my HP Officejet 7000 printer and everything seems OK (see attached picture - IMG_0303.JPG). I also exported your PDF to JPG in Preview.app and again - everything looks right (attached "FRONT DOOR OPTIONS 1 07JAN2013.jpg").
The two things I've noticed in your PDF:
1. The stroke width of the lines in PDF are 0.000 mm - as Adibe Illustrator shows.
2. The color of hatch lines is light gray.
I think those factors could be the cause of your troubles.
Maxim
Architect
MARSS
MacACAD | MARSS
