I've used ACAD for years on the PC but am new to ACAD on the Mac. I'm having troubles with layouts. I would simply like to duplicate and/or delete layouts. From everything i can tell the only way to do it is through the "show drawings and layouts" button on the status bar. However when I go into that and right (control) click on a layout I only have 3 options that appear in the contextual menu:Print, Edit Page Setup and Page Setup Manager. From what I've researched I should be getting at least: Rename, Duplicate..., Delete and Create New Layout as well. What am i missing??? Please help.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
This seems work on my system.
If you are using AutoCAD 2013 for Mac on Mavericks (10.9.x) - have you installed SP2 for 2013?
Here is the link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22614738&linkID=15839491
Maxim
