The layer window is not visible although it shows the tick when I check the Window menu. Switching it on and off via the Window menu or by using cmd4 does not have any effect.
Tried to shut down AutoCad and also restarted the machine- nothing seems to bring it back.
I am on AutoCad LT 2013 for Mac.
Thanks for any comments!
Solved by maxim_k. Go to Solution.
Sorry for my lack of experience...but how do you save the customized toolset? I located the folder you mentioned
Library/Application Support/Autodesk/roaming/AutoCAD LT 2014 Standalone/R19.1/enu/support
That folder has 30 items inside, 4 of which are .cui files. Now what?
Thanks in advance
-J
