I have a floor plan on a yellow layer and windows on a green layer. I would like to put the windows on the yellow but it wont allow me. If i check properties on the yellow lines to floor plan they are yellow by layer and if i check the green windows properties it says yellow by layer also, but windows say properties says its on a block.
Can anybody help or understand what I am asking?
Question #2
On the floor plan I have been showing display fixtures that I have been extruding and modifying from there up into 3d and put them into new layers. So my question is do I leave the outlines of the fixtures on the floor plan and do I leave them on floorplan Layer or should i delete outline after I extrude them. Any suggestions?
Hi i'm trying to offset my wall and of course it stays the layer i'm offsetting from but how could I change it to a different layer by clicking on it, its dimmed where it says make active with the right click? just wondering if somehow I turned that option off or whats going on if you could get back to me soon that'dbe great! i have Cadd 14 for mac
Welcome to the Autodesk Forums!
@storm.mccarthy wrote:
Hi i'm trying to offset my wall and of course it stays the layer i'm offsetting from but how could I change it to a different layer ...
When you use OFFSET command set current the Layer you want to have the result of offset to be paced to, than use Layer option after you start OFFSET command, than select "Current" option instead of default "Source", than proceed with OFFSET as usual:
Command: Of OFFSET Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0 Specify offset distance or [Through/Erase/Layer] <31.6019>: L Enter layer option for offset objects [Current/Source] <Source>: C Specify offset distance or [Through/Erase/Layer] <31.6019>: Select object to offset or [Exit/Undo] <Exit>: Specify point on side to offset or [Exit/Multiple/Undo] <Exit>: Select object to offset or [Exit/Undo] <Exit>:
...its dimmed where it says make active with the right click? ...
Sorry, can not understand what about you are writing? Are you about Layers palette? "Make active" in context menu are dimmed for
Maxim
