AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
LAYDEL command in Autocad 2013
6 REPLIES 6
progvincent
6413 Views, 6 Replies
I'm trying to delete a unused layer. But when I do that I get the following error (see attachment). I googled a bit and figured out that the LAYDEL command might solve my issue, but as I'm using Autocad 2013, that's not possible, as it doesn't have this command... Any id's how to solve this?
The block that causes the error can also be deleted, I tried with the purge command, but must be doing something wrong cause it didn't work. Oh yeah, with regard to the purge command, I see it this way (attachment 2), how can you display it in a window kind of view to get a better overview?
Best regards,
Vincent
6 REPLIES 6
maxim_k
in reply to: progvincent
LAYDEL and it's functionality command is not available in AC for Mac.
PURGE command in AC for Mac has only command line interface, you can not use dialog box unfortunately...
Sometimes I also can not delete Layer (or move Layer objects to another Layer) with AutoCAD for Mac functionality by dragging Layer from Layers palette. And I get the same dialog as you about objects inside block definition.
I have found that if I have dimension object(s) on the layer, that I want to delete - I can not delete such layer, because dimensions treated by AutoCAD as blocks, plus arrows in dimensions are also blocks, and AutoCAD for Mac can not move dimension objects to another layer when you drag off layer from Layers palette.
Moving all dimension objects to another layer, or deleting them helps me in this case.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
mjhabig
Hi Maxim
I too am trying to rid my base drawings of layers brought in on a block.  How can I do this?  I have editted every block in the drawing and put all its layers on the layer I want to keep, but still get the message that these layers on in a block.  Why why why did they make the Mac AutoCad so user unfriendly??
Thanks for your help!
Mindy
maxim_k
in reply to: mjhabig
Hi Mindy,
it may depend on the file itself, sometimes I can not get rid of some layers in the file.
But you may try -WBLOCK command with "*" option to write whole drawing to new DWG file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
KatherineEippert
in reply to: maxim_k
The -WBLOCK command worked for me!  I did this and saved as a new file name, when I opened the new file all of the layers that previously said they couldn't be deleted were gone.  Thank you for the help!
Emmsleys
in reply to: KatherineEippert
@ katherine.fishburne,
Thanks for posting what worked for you and what helped.
I don't know if the OP will be back to this thread but I'm sure other users who might be in a simialr issue will find this helpful.
Thanks for sharing! 🙂
Sarah Emmsley
Technical Support Specialist
”Boost
