What am I doing wrong? Every once in a while I lose my keyboard functionality in AutoCAD 2012 for Mac. Can't save, use the enter key, etc. But I can still use the mouse to go to menus, etc. The only way I can reset it is to quit and relaunch AutoCAD. I am inadvertantly doing something that disables the keyboard?
Could you provide step by step information?
For example:
I do so and so (call some command, open dialog, trying to print... etc.), then I loose keyboard input.
Maxim
Hi, I can't get it to do it on demand and I am not sure what order it happens. It just happens once in a while. Someone suggested typing PICKFIRST in the command line and setting it to 1 but that doesn't fix it.
The same thing happens to me. I use AutoCadLT for a few hours sometimes, then i hear this click click click click noise in the speakers and the ketboard is disabled. I can still use the ESC key and CMD-TAB and the M key workds but nothign else. Requires a reboot to fix.
This only happens in CAD, if I dont use cad for a few weeks the problem never occurs, Use CAD for an hour or so (or maybe less) and I will loose the kayboard guranteed.
Thanks Maxim
Running AutoCAD LT 2014 (I.18.M.314) on OSX 10.9.2 on a macbook pro retina mid 2012 model
When the keyboard freezes I not only loose AutoCAD but the entire system is affected in all applications, required a hard reboot to get the keyboard back. Mouse works fine, its just the keyboard, and then its only the character set. All the function keys and controls work as does the CMD-TAB buttons etc.
I have not been able to determine if its any one command. This morning I was just doing some simple DIST, LINE, MOVE and ROTATE and it happened. It does seem to be occuring when I use the command line over the mouse.
More news
I reset my PRAM. No luck. Have also reset all settings in CAD. No Luck.
However last night I was using CAD to just look over dome drawings, so no creating just zooming in and out.
It happened then, so it might be that this happens when you are holdoing down the CMD key and then using the trackpad to zoom in and out. Which I tend to do alot.
Getting very fustrating 😞
Apologies, it is the OPT key.
You nailed it! When you press OPT five times in a row, you get the issue.
I am a very happy camper. Thanks so much! I guess autocad is the only app I ever press opt more than 5 times 🙂
Thankyou!
