hi i have a problem in viewport, autocad 2013 for mac wont show casted shadow, for light have no problem, im on a mbp with nidia gt 330 that accrding to autodesk is compatible (they say all hardware supported) latest driver, activated csted shadow in properties but nothing , had a try with sun and lamp but nothing... some suggestion? maybe some not compatible with hardware acceleration? had checked -3dconfig command and all is set by default on ON.... tnx cant call the support because im on student version, so you guys are the only hope to find out 🙂
Do you mean this?
You can get such effect if you set your preferred Visual style (Realistic, Conceptual, Shaded, Shades of Gray, Shaded with edges) and then change system variable VSSHADOWS=2.
Maxim
