Hello.
I have a new macbook air
10.10.1 ox s yosemite
Intel HD Graphics 5000
Is autocad 2015 sould work? I try to install it and when I open it, in the first screen when it's write ״Loading..." on the left down it's get stuck and not open the software.
pealse help me. I need this as soon as fast for my studies
thanks
Solved by danielyosef7. Go to Solution.
@danielyosef7 wrote:Hello.
- 1.7GHz Dual-Core Intel Core i7, Turbo Boost up to 3.3GHz
- 8GB 1600MHz LPDDR3 SDRAM
- 128GB PCIe-based Flash Storage
thanks
I couldn't find any answer for my problem!
I tried to also install 2015 sp1 and its still not runing the Software!
when I installed the Software I wrote the Serial number and Product key that I get to my e-mail and that's all.
when I try to open the Software it's show me the window that I upload on my first message and after 30 sec that it's not doing nothig and it's Not Responding.
I never get to this window that you are talking about
I guees it's Not Responding before this window
Could you post here System.log file output from Console.app from the moment when you pick AutoCAD icon in the Dock till the moment when you need to Force Quit it?
Maxim
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.1 instead of 10.10.1. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 0 CarbonCore 0x00007fff8d724dc3 ___Gestalt_SystemVersion_block_invoke + 113
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 1 libdispatch.dylib 0x00007fff83ccec13 _dispatch_client_callout + 8
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 2 libdispatch.dylib 0x00007fff83cceb26 dispatch_once_f + 117
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 3 CarbonCore 0x00007fff8d6cd4da _Gestalt_SystemVersion + 987
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 4 CarbonCore 0x00007fff8d6cd0c7 Gestalt + 144
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 5 QtCore 0x0000000110705916 _GLOBAL__I_a + 22
Dec 5 18:07:48 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: 6 ??? 0x00007fff63ae4ceb 0x0 + 140734865755371
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local AutoCAD[2494]: ApplePersistenceIgnoreState: Existing state will not be touched. New state will be written to /var/folders/70/p7vz3h0d0qd7cj2101p0k7b00000gn/T/com.autodesk.AutoCAD2015.savedState
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2497]: 2497 DAEMONIZE: setting umask 0
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2497]: 2497 DAEMONIZE: session parent exiting
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2498]: 2498 DAEMONIZE: session new session leader
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2497]: exiting and supressing hooks: 0
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2498]: 2498 DAEMONIZE: tty disconnect parent exiting
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2499]: 2499 DAEMONIZE: tty disconnect child
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2499]: 2499 DAEMONIZE: closing file descriptors
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2499]: 2499 Execing /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/lmuopen
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2499]: 2499 with argument: lmuopen
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2499]: 2499 with argument: /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/LMU
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local lmuopen[2499]: Launching: /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/LMU
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local lmuopen[2499]: *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: 'launch path not accessible'
*** Call stack at first throw:
0 CoreFoundation 0x9b2d2343 __raiseError + 195
1 libobjc.A.dylib 0x9a80ea2a objc_exception_throw + 276
2 CoreFoundation 0x9b2d225d +[NSException raise:format:] + 141
3 Foundation 0x9c01078b -[NSConcreteTask launchWithDictionary:] + 642
4 Foundation 0x9c00fd58 +[NSTask launchedTaskWithLaunchPath:arguments:] + 258
5 lmuopen 0x00004e0f main + 431
6 lmuopen 0x00004c15 start + 53
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel com.apple.xpc.launchd[1] (com.apple.ReportCrash[2500]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local LMU[2498]: exiting and supressing hooks: 0
Dec 5 18:07:51 h-MacBook-Air-sl-Daniel.local ReportCrash[2500]: Saved crash report for lmuopen[2499] version ??? to /Users/danielyosef/Library/Logs/DiagnosticReports/lmuopen_2014-12-05-180751_h-MacBook-Air-sl-Daniel.crash
Dec 5 18:07:58 h-MacBook-Air-sl-Daniel kernel[0]: process AutoCAD[2494] caught causing excessive wakeups. Observed wakeups rate (per sec): 4517; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45089
Dec 5 18:07:58 h-MacBook-Air-sl-Daniel.local ReportCrash[2500]: Invoking spindump for pid=2494 wakeups_rate=4517 duration=10 because of excessive wakeups
Dec 5 18:07:58 h-MacBook-Air-sl-Daniel.local spindump[2274]: Saved wakeups_resource.diag report for AutoCAD version 20.0.51.311 Copyright © 2009-2014 Autodesk, Inc (20.0.51.311) to /Library/Logs/DiagnosticReports/AutoCAD_2014-12-05-180758_h-MacBook-Air-sl-Daniel.wakeups_resource.diag
Dec 5 18:07:58 h-MacBook-Air-sl-Daniel.local spindump[2274]: Removing excessive log: file:///Library/Logs/DiagnosticReports/AutoCAD_2014-12-05-130634_h-MacBook-Air-sl-Daniel.wakeups_resource.diag
Dec 5 18:09:49 h-MacBook-Air-sl-Daniel.local mdworker[2503]: code validation failed in the process of getting signing information: Error Domain=NSOSStatusErrorDomain Code=-67030 "The operation couldn’t be completed. (OSStatus error -67030.)" UserInfo=0x7fbac6395800 {SecCSArchitecture=x86_64}
Dec 5 18:09:50 h-MacBook-Air-sl-Daniel.local mdworker[2501]: code validation failed in the process of getting signing information: Error Domain=NSOSStatusErrorDomain Code=-67030 "The operation couldn’t be completed. (OSStatus error -67030.)" UserInfo=0x7fb965fb15e0 {SecCSArchitecture=x86_64}
Dec 5 18:12:12 h-MacBook-Air-sl-Daniel com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
From your log I can clearly see that LMU (License manager Utility) cannot properly start on your system.
I also see this strange warning from AutoCAD:
Strange, but AutoCAD 2015 should work on 10.10.1 especially if you installed SP1 for AutoCAD 2015.
I don't have any suggestions except one - try to reinstall AutoCAD:
remove it with "Remove AutoCAD.app" with deleting user preferences during removing, than install it again and apply SP1
Maxim
If you still cannot get AutoCAD running, could you try this solution: http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
I did it, but again I have the same problem!
still stuck on this "loading.." Screen
thank you all!
I found the problem !!!!
My os x was in Hebrew and when I change it back to english and try to open autocad it's work all fine!
I guess when the os x is in Language that autocad not support then it's not wotking!
thanks again to everyone that try to help me!
Thanks for confirming this. We've known this problem of launching hang in Hebrew/Arabic language and are researching on it.
