after installing AutoCAD 2012 on Mac OS 10.7 I am experiencing major dificulties. My pointer/crosshair and selection pane are not visible in model space.
If I switch to paper space, everything works as it should. But if I create a mview port in paperspace and double click into it, my pointer is invisible in the model area. But as soon as I go out of it, with model space are still active, I can see my pointer again.
Any ideas? Please hlep.
Thanks!
I'm having that issue and have had that same issue even after multiple updates. Would love to be a beta tester for the the mac products. My MBP meets and exceeds all the specs needed too. I've even done a reinstall, with out much luck. It's not a user defined setting. The visible cursor just dissappear during operation. The only way I can get auto cad to remember to display is to relaunch the app. Yes I've trash the preferences. My cursur seems to forget what tool its using form time to time too. Its all random. Along with the scroll wheel action works with zoom functions SOMETIMES, but never consistantly.
Hi user,
Do you mean that the crosshair is missing in the Model?
Can you attach the screen shot for your drawing canvas and the setting for Preferences?
Does this issue resolved after you reset the application?
I need you help on repro this issue and log defect.
Leaf
Autodesk Test Engineer
I just had this happen to me. I was working on converting some text to mtext with a layer isolated when all of a sudden my crosshairs went AWOL. I checked color scheme and background is set to black and crosshairs are set to white (how I prefer to look at the screen) and I even tried chaning the crosshairs to red just to see, and it did nothing. What gives?
RRice
This just started happening to me. I tried looking at my memory usage to see if something was there, cpu usage, anywhere.
If you are still having this problem keep researching it online. I write this response because the setting of crosshair colors was
one thing that never occurred to me. Now my crosshairs are different colors in model space and layout/paper space. This worked!
