Hi all,
I'm trying to import other files and can't get it working. I've tried .sat, .stp, .igs, and even .dxf and nothing works.
To import .sat I've been doing insert > ACIS file > open
For .stp, .ign and .dxf I've been doing FIle > import > open
When I do this, nothing happens.
Is anyone else having this problem?
Thank,
Ben
* running the educational version of AutoCad 2013
Solved by maxim_k. Go to Solution.
Hi Ben,
In AutoCAD for Mac you can only import .SAT files (via insert > ACIS file, or File > import), .stp and .igs doesn't supported. I don't have .SAT files, but I was able to open sample .SAT files from here:
To open DXF file you have to select File->Open and in File format drop-down list select .DXF filter.
Maxim
Hi thanks for your reply,
Those sample .sat files worked fine. There must be a problem with the other file I was trying to import.
