I am relatively new to mac and autocad. I am trying to import a screenshot into autocad for a project, but i can not save that screenshot as anything compatible with autocad itself, such as a dwg or dxf file. Any suggestions?
Solved by Alfred.NESWADBA. Go to Solution.
try command _IMAGE, then you should get asked to show an image that can then be referenced.
BTW: the forum for AutoCAD on Mac is >>>here<<<, I don't have a Mac (because I drive AutoCAD 😉 ), so I'm not sure if the above tip works.
Good luck, - alfred -
In AC for Mac IMAGE command opens Reference Manager palette, from which you can attach raster images (your screen-shots) to the drawing.
Maxim
