I have a design originally written in pro desktop that needs to be modified It is saved as an igs file, and a jpeg can this be imported into auto cad? If so how?
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
You can not import IGES files to AutoCAD for Mac (although you can do this in PC version of AutoCAD).
You can attach JPG file to AutoCAD drawing - use menu Insert -> Raster Image Reference.
Do you need to edit the model you created in Pro Desktop?
If you need to edit it you have to try to export to DXF or SAT format from Pro Desktop. AutoCAD for Mac can import such files for further editing.
Maxim
