I was using the program which is AutoCAD 2012 with my old computer that it was Windows. But now, Im using Macbook. So, the problem is that how can I change the macosx surface to windows'. Is it possible to do that?
There is a picture that I took the macosx surface.
Thank you.
Solved by pendean. Go to Solution.
Solved by maxim_k. Go to Solution.
Thank you for the reply,
Yes I mean about ''the surface'' its appearence or design. I understand what you mean. You know after using the program on Windows, it can being complex liitle bit. So, is there an option that How can I use to osx's autoCAD after Windows'? I think the question is really irrelevant but I wanted to ask.
Thank you for the reply.
Thank you for solving my problem as soon as possible.
Have a nice day.
