Hi !!
I downloade Mavericks with out thinking it was not going to be compatible with AutoCad 2013. SInce I did the download last wee the command line is not the same and every time I tried to format a dimension style the program starts thinking until I have to force it to quit.
Could you please let me know what should I do?
Thank you,
Lina
Solved by maxim_k. Go to Solution.
Hi Lina,
If you are using full AutoCAD version (not LT) and want to use it before Service Pack will be released, there is the only one solution:
HTH
Maxim
Hi Lina... I just posted a thread on subject matter since I have similar problem with 2013 on Air and Maverick... ACAD is working on resolving issue...from what I hear problem arise from different sources..I could never opened ACad 13LT on Maverick, suppposedly since I have too many blocks on content libray, which is strange I tried ACADLT 2014 MAC and it worked fine for a day (I removed it to keep seeking solution to ACAD 2103 and protect my investment)..Eventually it crashed as well but could feel some improvement in the 2014 version..
BTW Sketchup works fine with Maverick!!
I been draging this for 3 weeks!!
