AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
how to setenv for default file format
3 REPLIES 3
1310 Views, 3 Replies
Since not all persons has updated to 2013, i would like to know how i can set autocad, so it saves always to the 2010 format.. and ofcourse for later how to put it back to 2013
thanks
3 REPLIES 3
maxim_k
(setenv "DefaultFormatForSave" "48") - will save as 2010 format DWG
(setenv "DefaultFormatForSave" "60") - will save as 2013 format DWG
Note that environment variable is case sensitive.
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Where is this code input? is it a regedit? is there a CAD file or start script?
I have found this indormation on a few different threads but no information on how to implement.
(I am IT and not a user of the application and I need to set this for all users.)
maxim_k
Hi Vincent,
This AutoLISP statement you have to type at the command prompt (Command line palette) inside AutoCAD. You have to execute this string only once in each AutoCAD installation, than setting for default format for save will remain until you change it.
Start AutoCAD, at the command prompt type necessary string, hit Return to execute statement - default format for save will be changed and saved in AutoCAD preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
