AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How To Lock Toolbars / Command line
6 REPLIES 6
1172 Views, 6 Replies
Geezo peezo! This is almost like starting from scratch.
My toolbars keep moving around and / or disappear. If I do the reset palletts another AutoCad program starts up and some of the bars show up, Burt not in the drawing I am in.
Restart AutoCad and the toolbars are still missing. The command line does not show up again.
Any suggestions?
Central Standard
6 REPLIES 6
pendean
AutoCAD version?
Your chosen OS?
in reply to: pendean
Acad Mac 14
Mavericks
maxim_k
My suggestions:
- Ensure that you installed Service Packs for AutoCAD (SP1 and SP2)
- Quit AutoCAD using menu AutoCAD -> Quit AutoCAD,
- Launch Activity Monitor application, look at the list of processes: if you will find AutoCAD instance in the list- kill it from Activity Monitor,
- Restart your Mac (don't forget to uncheck "Open running applications at next login"
- Launch AutoCAD after restarting, use Reset Palettes from Window menu, arrange palettes as you need, Quit AutoCAD using Quit AutoCAD from menu.
- Start AutoCAD again.
If this doesn't help, than you can also try to Reset AutoCAD from Application tab of AutoCAD Preferences. Plus you can try to trash Profile.aws file (I will tell you how to find it little bit later)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
You can find Profile.aws file in:
~/Library/Application Support/Autodesk/roaming/AutoCAD 2014/R19.1/enu/Support folder.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thank you. I will give your suggestions a try.
Central Standard
Well, I'm back and thisclose to tossing the program out for the simple lack of consistency in menu location and appearance. Sometimes they are there, sometimes they are not. One day all my menus show up, another day some of them show up and then another time none of them show up. What is on the left one time will be on the right the next. Menus I don't want show up. They change width depending on which way the wind is blowing.
What is it with you folks at Autodesk that you can't get your program to work (at least as menus are concerned) consistantly as with a PC? I should not have to be hacking CUI files to get stuff to work in a consistent manner.
Phffft!
”Boost
