AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How to bring over dimension styles or text styles on Mac
2 REPLIES 2
dfandrews
1696 Views, 2 Replies
This has probably been addressed before but I'm unable to find it.
Since there is no Design Center on the Mac version of AC is there some way to bring over dimension/text/multileader styles from one project to another so we don't have to re-invent the wheel so to speak?  I'm using ACLT on a MAC running Mavericks.
2 REPLIES 2
maxim_k
in reply to: dfandrews
I'm using this trick to bring dimension/text/multileader styles from one drawing to another:
1. open DWG with already created Dim/Text/Mleader styles
2. save it as temporary file, delete everything from it with "ERASE all", purge everything except Dim/Text/Mleader Styles and save it.
3. Open file where you want to bring Styles, call INSERT command, select file you created in step #2, check mark "Explode Block", then proceed with insertion.
4. Now all Dim/Text/Mleader Styles are in destination DWG ready for use.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
dfandrews
in reply to: maxim_k
Once again, thank you so much.
”Boost
