Well, I was trying to save it but I couldn't It doesn't appear when I look for it and I save it with the the template acad.dwt. Hope you guys can help me!!
Welcome to the Autodesk Forums!
Where are you trying to save your DWG file? Is it some location inside your home folder? Network drive?
Do you get some alert from AutoCAD?
What do you see on the drawing window title bar? Do you see the name of the drawing file you just saved?
What if you Command click on the DWG icon on the title bar of the drawing window? (you should be able to see full path to your drawing, and if you click on the upper folder name you should be able to open this folder in Finder).
Maxim
I'm trying to save it on a network drive but it neither saves it on my folders, I'm not able to open it on finder, It's like I haven't saved it. I look for it and I can't find it.
