Solved by maxim_k. Go to Solution.
hi - i have these 2 blue squares as well and the command CONSTRAINTINFER give me press F1 for help..Parametric didn't work either. . I am using AutoCad Lt for Mac on Mojave. Thanks
Hi @mjhabig ,
In AutoCAD LT, parametric drawing technology is limited to the following areas:
- Displaying and hiding constraints
- Editing and manipulating constrained geometry
- Changing values in the Parameters Manager
That is why CONSTRAINTINFER command is not available in AutoCAD LT.
If geometric constraints were created in full version of AutoCAD, you can still view them in LT version.
If you are sure that "blue squares" are geometric constraints you can delete them with DELCONSTRAINT command.
