AutoCAD for Mac General Discussion
Member
claudiapintobravo
Message 1 of 6 (1,831 Views)
How can I scale materials??
1831 Views, 5 Replies
10-12-2012 03:40 PM
firs of all sorry for my bad english :smileyhappy: I´m starting to use autocad on a mac, I have autocad 2012 instaled on the computer, and I can't change the scale (size), of the materials (3d environment). Can anyone help me find a way to do it? Or explain to me how can I do that?
Tank you so much :smileyhappy:
maxim_k
Message 2 of 6 (1,823 Views)
Re: How can I scale materials??
10-12-2012 11:50 PM in reply to: claudiapintobravo
Unfortunately in mac version of AutoCAD you can not scale (or adjust) materials maps, but here is one trick:
Before assigning material to some object you can scale it down (if you want material to be scaled up) or scale it up (if you want material to be scaled down), then assign material and then scale your object back to original size:
Maxim
Architect
MARSS
MacACAD | MARSS
Member
claudiapintobravo
Message 3 of 6 (1,813 Views)
10-14-2012 03:25 PM in reply to: maxim_k
HI, thank you for the quick answer :smileyhappy:
i'ts possible to do that resize inside autocad? before aplly the texture? Please tell me how to do it, where sould i go to modify the scale?
Thank you once again :smileyhappy:
maxim_k
Message 4 of 6 (1,806 Views)
10-14-2012 06:09 PM in reply to: claudiapintobravo
Yes, inside AutoCAD.
Create your geometry (3D), scale up it with SCALE command, assign material, then scale down in order to scale down the material. Do opposite in order to scale up the material.
Maxim
Architect
MARSS
MacACAD | MARSS
Member
claudiapintobravo
Message 5 of 6 (1,796 Views)
10-15-2012 07:16 AM in reply to: claudiapintobravo
Thanks for the response. I tried but the material is always at the same scale, either increase or decrease a cube for example.
maxim_k
Message 6 of 6 (1,788 Views)
10-15-2012 11:15 AM in reply to: claudiapintobravo
Strange, very strange.. You have seen rendering example, that I have made in AutoCAD for Mac. Could you agree, that materials on boxes have different scale?
Could you post drawing with geometry you want to assign material? And a name of material you want to assign. I can try...
Maxim
Architect
MARSS
MacACAD | MARSS
