Hey everyone,
Currently I'm doing a work for the university and needed to plot a layout with a viewport set to the HIDDEN visual style. Whenever I plot the layout as a pdf the outline of the 3d objects is really thick (as you can see in the image). I would like every line to have the same thickness as the one set for the layer the object is on. Is there any way I can do this?
I'm using Autocad 2013 for Mac.
Hope you can help,
Thanks in advance.
Welcome to Autodesk Forums!
Try this:
Select Viewport you are plotting in Layout, in Properties palette find "Shade plot" property, open drop down list and select "Legacy hidden".
Now try to preview PDF.
Maxim
Thank you Maxim,
I had to use legacy hiden, but It worked.
Then I kept working and had another problem when plotting cylinders (as you can see in the image). Any tips on how to get rid of the lines on the surface of the cillynders?
Tomás
Maxim,
Thanks for this suggestion. I was also having this issue.
One thing that did pop up. When I switch to the Legacy Hidden shade style, none of my text plots on the layout.
Any insight?
