I'm new with autocad on mac and i would like to change the configuration of my working space and save it as my onw. How can i do that ?
Welcome to the Autodesk Forums!
There is no special tool for managing Workspace in AC for Mac, but you can setup your workspace as you need, than after you quit AutoCAD the settings are saved in Profile.aws file which is inside
"/Users/YOUR_USER_NAME/Library/Application Support/Autodesk/roaming/AutoCAD 2014/R19.1/enu/Support/" folder
You can save a copy of this file for future restore on the same Mac.
Settings that are saved within this file are:
- size and position and state of all opened Palettes (Layers, Properties. ToolSets, Command Window, Status Bar, etc.) at current screen resolution
- current set of tools opened in ToolSets Palette
- settings for Hidden AutoCAD messages - all message boxes that you marked to not display again or to always use a specified option in them, such as:
HTH
Maxim
