AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Help: Alert message
9 REPLIES 9
Message 1 of 10
mitchelllance
843 Views, 9 Replies
Help: Alert message
I have not opened AutoCad in 2 months, and received this message when I did:
The directory may be locked by another procees or haven been set Read Only. Directory: '/users/myusername'
Please correct this problem and press OK to exit the application.
Can somone please advise me what to do. Thank you!
9 REPLIES 9
Message 2 of 10
maxim_k
in reply to: mitchelllance
I can suppose:
1. Something happened with permissions for your home folder
or
2. Something happened with your user id
For the first assumption - Try to repair permissions in Disk Utility.
For the second assumption - Can you try to run the following command in the terminal:
id -u "your_user_name"
where "your_user_name" is your short user name (in quotes) on Mac.
What result do you get? (should be 501)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
fangh
This indicates you don't have write permission on your working directory where AutoCAD needs to put some settings. Could you donwload the zip file attached and run the test.app after unzipping then let me know the result?
Hao Fang
AutoCAD Test Development
Message 4 of 10
mitchelllance
in reply to: fangh
Hi Hao,
I ran the test and got a similar error message:
The directory may be locked by another process or have been set Read Only.
Directory: '/Users/mitchelllance'
Thanks for the help!
Message 5 of 10
mitchelllance
in reply to: maxim_k
Hi Maxim,
When I plugged this into terminal I got 502...not the result I wanted.
Is there a fix? Thanks!
Message 6 of 10
maxim_k
Hi mitchelllance,
In order to run AutoCAD it should be 501.
If you was able to run the application on your Mac previously (just after first installation), could you remember what was happened to your system during last two months?
Could you try to create new account on your Mac and try to start AutoCAD from this new account?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 10
mitchelllance
Your right about this...
I was able to open AutoCad from my Guest user account....
The only system change since installation was the deletion of an old system user. However, AutoCad was never used or installed with that user account. Any suggestions? thanks
Message 8 of 10
maxim_k
It seems to me, that by default, when you install Mac OS or add new user to it System creates new user with User ID 501 (I have never seen another variant). So there was some "System fault" when you deleted an old user. I think, that developers of AutoCAD are aware of this "501 user problem", but there is still no easy solution to it.
If you will google Internet with "user id mac os", you will find a lot of solutions for changing UID, but I had never tried these by myself. The only thing I know - changing User ID might damage your account and prevent you from logging in your account.
So be careful!
Wait for answer from Autodesk stuff.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 10
mitchelllance
Problem solved. I changed the application folder permission to read and write. Not sure why this ever changed, but at least now it's working. Thanks everyone
Message 10 of 10
can you tell me how you did that?
”Boost
