Hi!
I have a biiiiiiig problem. I have tried everything and I can't read hebrew in my plans.
I have an iMac working with OSX 10.9.2 and AutoCAD 2013 educational version.
How can I solve this problem? I'm getting crazy!!!!
Thank You very much.
Clara
Solved by maxim_k. Go to Solution.
Hi again and thank you for your answers!
My problem is that I have many many plans in hebrew, plans I made in Windows with my last computer. Now I'm working with an iMac and AutoCAD 2013 Educational Version, and when I'm opening those plans I can't read hebrew at all: I just can see the equivalent letters in english and with mirror effect and sometimes I just can see "?????????????", that's it. That's the first problem.
The second one is when I'm creating a new *.dwg file. I can write in hebrew, yes, but I have to write the backwards. For instance: if I want to write "plan" in hebrew I have to write "nalp" to see this in the right way.
I'm sending you one of my problematics hebrew file to show you my priblem.
By the way: I have many hebrew fonts and I tried everything I found on forums and I can't get it anyway...
Hope you can help me.
Thank you very very much!
Clara
Hi Clara,
After adding two SHX fonts (Michal_m.shx and Sivan_m.shx) to /Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/Fonts/shx folder I am able to see Hebrew text in your drawing:
In order to get to this SHX folder you need to go to Applications folder on your Mac, find AutoCAD 2013.app, right-click on it and select "Show Package Contents", then type SHX in search field in Finder (upper right corner of Finder window), scroll down until you will see SHX folder, double-click on it - you are in right place - copy Hebrew SHX files here.
As about input method (direction of text input) - I'm afraid, I can not help you. When you use PC version of AutoCAD - could you use the correct direction of Hebrew text input inside AutoCAD?
Maxim
Hi again!!!
I did it!!!!!
Somebody from Israel called me when he saw my post and gave me a great great help!
It was like you told me in your last answer.
Thank you very much!
I'm sooooo happy!
Clara
hey clara, can you please tell me how you did it ? i can't read hebrew in my plans also!
Welcome to the Autodesk Forums!
Have you tried this:
Maxim
Hi!!!!
The solution is here, same page. Read it and do it just like this...
Another way to get to SHX folder:
While you are in Finder, select "Go" menu, then "Go to Folder..."
If you have AC 2014: copy this string:
/Applications/Autodesk/AutoCAD 2014/AutoCAD 2014.app/Contents/Resources/Fonts/shx
and paste it to "Go to Folder" window, then pick on Go button.
For AC 2013 the string is:
Maxim
hii Maxim,
I'm trying to install a Hebrew font to my Autocad 2013. I follow the steps yo have written but after the step os writing the SHX in the search bar i got lost. i dont have the file of SHX fonts as you sad...
lm losing my minde! please halp
I added the screen shot of the search results so you can check if I did something wrong.
tnx
Adi
Hi Adi,
Have you tried this (the second post above yours):
If you have AC 2013 - copy this string:
/Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/Fonts/shxand paste it to "Go to Folder" window, then pick on Go button.
You should be inside SHX folder where you can put your fonts - you can drag your SHX fonts here
Maxim
Thank you for your reply. i have the hebrew fonts - but still writing backwords.
(i am working on Autocad 2015 for mac)
thank you
Anat
Thanks for the information.
After placing the fonts in the SHX folder I can read the Hebrew text when I open the file. But, once I click on it, the text turns into a row of ?????.
How could this be fixed?
Gal
