AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Hatch doen't show
9 REPLIES 9
Message 1 of 10
4749 Views, 9 Replies
Hatch doen't show
Hey everyone
I'm having problems hatching in autocad 2012 for mac. Every time I hatch it doesn't show, when I put my cursor on it, it lights up and I can select it, but it just doesn't show, not even when I plot the drawing. It's not a matter of scale because it's a solid hatch and I have tried with other hatches too. It's not a matter of drawing order either. Has anyone had this problem before who can help me out?
9 REPLIES 9
Message 2 of 10
maxim_k
What do you mean by "it doesn't show", if you can select it - it exists and you can see it. maybe hatch color or transparency settings are the case?
Could you provide screenshots (before and after selection hatch)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
in reply to: maxim_k
Hey, thanks for the reply.
I've made 3 screenshots, the first is of the hatched drawing, but, as you can see, the hatch doesn't show, the second is of the hatch if i select it, the third is of the hatch properties. I already tried changing the color and the transparancy is 0.
The problem only seems to occur when I use the solid hatch...
Message 4 of 10
maxim_k
Does this happens in specific file? Or in all files?
Have you tried to switch to 2d Wireframe visual style?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 10
Hey
changing the view to 2D Wireframe seems to have done the trick, I have no idea why it the view was "hidden" anyway.
Thanks a lot! 🙂
Message 6 of 10
My hatching or thick lines are not plotting when I hit plot. I have typed FILL and made sure that that is turned on. I can not figure the problem out. Can anyone help? I have attached a drawing. There are supposed to be five circles and two triangles that are filled in...
Message 7 of 10
maxim_k
Welcome to the Autodesk Forums!
What hatch pattern do you use for filling triangles ans circles?
Please, be sure to put the hatch to printable layer.
Without original drawing I can not advice more.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
Good Morning,
Can you view this drawing? I'm not using a Mac...I see that the topic group is AutoCAD for Mac.
I'm using Windows7...
I believe that all the layers are set to be printable.
Message 9 of 10
maxim_k
In Plot dialog set "Shade plot" in "Shaded viewport options" to "As displayed":
If you want color fill for circles and triangles and if you use monochrome.ctb Plot Style table - set the color of Solid fill to True Color, not one of the ACI colors (that have numbers from 1(red) to 255(gray)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
THANK YOU!!!!
I will take a closer look at this mistake in all of my other drawings but did the fix for the drawing that I'm on a deadline for and that was all it took.
THANKS AGAIN!
