The find and replace text function has suddently stopped working for multiple words. I used to be able to replace several words at a time, even whole sentences with multiple words or whole sentences. Now, I can only replace single words. No idea what would have caused this.
I could replace THE BLUE CAR IS SLOW with THE RED CAR IS FAST in a dwg file with no problem using any of the three selection settings. Now I can't do that anymore with any of the selection settings. I can replace BLUE with RED, but not BLUE CAR with RED CAR.
Is there a system variable that might have gotten reset somehow? Did the program change somehow?
Thanks. This is AutoCAD LT 2013 for MAC.
Solved by maxim_k. Go to Solution.
I am both stunned, and grateful. I was sure that I had selected and unselected all combinations of those variables, but apparently I did not try that one. It worked!!! I've spent hours trying to figure this out after not having problems for years. Crazy!
Thank you for taking the time to respond.
Maxim, how about Mtext words on separate lines? It finds only top line word, any fixes?
Thx
Maxim, you have my file above, I am trying to write a macro that would make it to jump to the second line and concatinate both, any suggestions? Thx
Many, many thanks to maxim k.
