Is a fast way to switch on the ortho mode in mac ? I used F8 on a pc but i dont know a shortcut on mac, rather than click on the tool bar located in the bottom of the screen ?
Arturo.
Solved by maxim_k. Go to Solution.
Hi Arturo,
The same on Mac - F8, with one proviso:
if you have a MacBook or Apple Keyboard - you must:
- either press Fn + F8
- either in Keyboard System Preferences check mark "Use all F2, F2, etc. keys as standard function keys.
HTH
Maxim
It works !!!! Thanks a lot.
Also works for the "Osnap" mode as I learned on a PC.
I did some research and there is one more option to switch on the orto mode: cmd+shift+ O .... But I prefer the traditional F8 and I think many users agree with me.
Again thanks maxim!!!
Yes, you're absolutely right.
For more shortcuts you can look at my post - here.
Maxim
Hi Jakub,
If you are using AC 2012 for Mac - you have to apply Update1 in order to be able to use F3, F8 function keys during command execution.
Maxim
