AutoCADLT 2013 for Mac will not export PDF or publish to PDF. It appears to be doing so when I export but the PDF is never there. I tried it with more that one file ( to make sure the file wasn't corrupted) and on both an external drive and my hard drive ( to make sure it wasn't a drive problem either). Is there a preference file I need to delete or is this just another incidence of AutoCAD being totally inadequate on the Mac?
Welcome to the Autodesk Forums!
Do you have this problem from the beginning? Or you was able to save PDF from AutoCAD before?
Try to batch publish from AutoCAD and after this call VIEWPLOTDETAILS command. What do you see in Plot details log?
Maxim
