Hi there!
I am working with excel points that countain x,y and z information. I would like to know how can I import that spreadsheet to the autoCAD with that spatial informations (like points) to draw into autocad?
Observation: My Autocad 2011 is a MAC version.
If somebody can do it, please give me a hand!!
Hugs!
Try this solution:
Save your file in Excel in .CSV format, then check if Excel uses comma or semicolon as delimiter between coordinate values in resulting .CSV file (generally it depends on International settings in System Preferences of Mac OS - if decimal separator is point, then you should get comma, if it is comma - you should get semicolon)
For comma delimiter load ASCPOINT.LSP,
for semicolon load ASCPOINT_CS.LSP,
then follow prompts in command line.
Maxim
