AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
EVERY command causing autocad to freeze for around a minute.
2 REPLIES 2
4906 Views, 2 Replies
Autocad 2013, for Mac.
I'm not running any particularly large files 10.8MB, and only drawing up 2D sections, all very simple.
I'm using maybe 8 or so layers.
It all started with copying items. After clicking on where I wanted an item to go, (even if it were two lines) it would freeze for a minute and the evil spinning wheel of death would come up.
But now it is with every command. I was want to draw a line. It taking forever!
To add, I am mostly self taught, this may be my downfall with autocad. And I've been doing things completely wrong.
Any help?
2 REPLIES 2
Alfred.NESWADBA
Also when you draw a line in a new drawing based on an original AutoCAD template?
BTW: there is a seperate forum for AutoCAD on Mac >>>here<<<, maybe you get faster/better response there.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
maxim_k
The same question as Alfred asked:
If it is not freeze in empty new drawing - another question:
Do you have external references (DWG) attached to your drawing(s)?
If so - please check: do you have PROXY objects, created by 3-rd parity applications in these attached drawings? That mean if you open externally referenced files in AutoCAD it gives you an alert like this one:
If so - look through this topic:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-for-MAC-2013-running-slow/td-p/3400143/page/3
from message #21
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
