Hello all,
I use AutoCAD 2011 on a 15" MacBook Pro. My CAD was freezing and crashing when trying to plot. After repetitive tries I force quit. When I went to open it again it would not and shows this error message:
Error Signature
Application: AtutoCAD
Version: E.49.H.62(x64)
Error: Unhandled Exception
The error report contains the following files:
crashLog.txt
dmpuserinfo.xml
dumpdata.zip
system_profile.xml
WHAT DO I DO??
Solved by maxim_k. Go to Solution.
Just want to be sure: Is it "Version: E.49.H.62(x64)", or "Version: E.49.H.602(x64)"? Because if you are on Lion and did not installed all Updates (1, 2, 3) AutoCAD will crash on print. and the correct version number after all three Updates should be "E.49.H.602(x64)".
And, of course, please send crash report to Autodesk, this will help to identify real problem.
Maxim
Hi user,
Thanks for contacting Autodesk.
Please install all the updates available for AutoCAD 2011 for Mac. You can get these updates from the following link:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=15839491
It is 62 right now, not 602. These are the details:
Model Name:MacBook Pro
Model Identifier:MacBookPro8,2
Processor Name:Intel Core i7
Processor Speed:2 GHz
Number of Processors:1
Total Number of Cores:4
L2 Cache (per Core):256 KB
L3 Cache:6 MB
Memory:8 GB
Boot ROM Version:MBP81.0047.B04
SMC Version (system):1.69f1
Serial Number (system):C02FGXZ2DF8V
Hardware UUID:197F91CB-9F3D-5031-9767-883001FEEF48
Sudden Motion Sensor:
State:Enabled
So if I install these 3 updates will it work again? Or would I need to uninstall and reinstall?
You should install all updates one after another (from 1-st to 3-rd) and you don't need to reinstall your current AutoCAD installation, it doesn't take much time and after applying all updates AutoCAD should run.
Maxim
Thanks. 2 and 3 loaded fine but the 1st one did not and so I could not install the rest..
When I try to open the 1st update in downloads it says:
AutoCAD 2011formacup no mountable file systems.
Try to re-download AutoCAD2011forMacUpdate1.dmg again, maybe something was wrong during first download and file was corrupted.
Maxim
When I try downloading the first update it keeps telling me no copy of AutoCAD is installed in my laptop. How do I fix this?!?! please help!
It says:
You do not have a copy of AutoCAD installed which can be updated.
Hi Autodesk,
I am running AutoCAD for Mac 2011 on a 15" new retina macbook pro. I have version 10.7.4 (which I believe is Lion). I downloaded all 3 of the updates for AutoCAD for Mac 2011 and my software is STILL crashing. It opens, I work on a drawing for a while, then it crashes. I am not sure what else I should do. This is driving me crazy!!!
Can anyone please help???
Evette
Hi Evette,
Theoretically it should work on Lion after you install all Updates, but....
Do you experience crashes in the same situation (could you reproduce the moment when crash occurs?), or crashes are random?
Maxim
I have the exact same problem. Autocad crashes randomly. Running Autocad 2011 for Mac on my late 2009 Macbook with OSX 10.7.5 (Lion). Ran the first update then got the message that my computer needs 3 MB of RAM. Went out and bought more RAM to upgrade to 4 MB total Ram then unistalled Autocad and reinstalled it. Ran all three upgrades o.k. and now it says Autocad is up to date. Still crashing randomly usually within first two minutes of use. Current I am running Autocad 2011 for Mac build E.49.H.602.
What can I do? It"s really un-usable. I can execute a few commands but then I have to save before it crashes. When I double click to load the file directly without first opening the application it loads a blank drawing insead of opening the file I clicked on my desktop. When it crashes the previously silent CD-rom drive starts up before it crashes.
Please, please help.
-jm
Does it crashes even on new empty drawing? I mean - you start AutoCAD and begin to draw without opening previously saved drawing.
About opening an empty drawing if you start AutoCAD by double-clicking on existing DWG. AFAIK it is knowing bug, not sure that was fixed with last update.
I also have to say, that 2011 version is less stable compared to the 2012 and 2013, especially on Lion.
Maxim
